TS420 Carb Needle Valve Pop Open Pressure
Automender
Active OPE Member
9:43 AM
Ohio
Working on a TS420 Stihl cutoff saw and came across an issue in the carb. On a K970 Husky I did the same test and the pop off pressure was about 15 psi. On this Stihl carb I did the same and I pumped it up to 25 psi and it didn't pop the needle valve. The needle valve is not stuck since I can press the metering lever and it pops. Is this normal. Also what is the sealant they use on the oblong welch plug in the picture?
riverrat2
Semper Fidelis
8:43 AM
N. Orange County, TX
I don't have my repair manual handy but 17 PSI is pretty normal for Stihl Chainsaws, I will call the Shop tomorrow and find out for the TS420...
I'm working out of town this week
